Einleitung
Use this guide to replace your HP Envy x360 m6-w105dx keyboard. You might need to replace your keyboard if the keys are sticky or unresponsive, or you can use this guide for keyboard removal to access the internals for cleaning and repairs. Before beginning, make sure to power off the computer entirely and disconnect from any external power source.
Was du brauchst
Use the opening pick to lift up the eight rubber grips on the underside of the device.
With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
Open the laptop and turn to the keyboard.
Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
Lift the keyboard panel from the bottom and carefully start to lift up.
Gently lift the keyboard up from the bottom.
Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
Fully remove the keyboard from the laptop and install your new keyboard.
Eine weitere Person hat diese Anleitung absolviert.
4 Kommentare
This guide is not complete.
This seems to gloss over a lot of important steps and details, “Fully remove the keyboard from the laptop and install your new keyboard.“
Keyboard is attached by plastic tabs, not screws. How do I remove and install the new keyboard?
Hello please i need to buy keyboard for my laptop envy 15x360
Model 15-u280nb. Please how can i get it
