Zum Hauptinhalt wechseln
HP Envy x360 m6-w105dx RAM Replacement
Was du brauchst
  1. HP Envy x360 m6-w105dx RAM Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Envy x360 m6-w105dx RAM Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Envy x360 m6-w105dx RAM Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Make sure the laptop is powered off and disconnected from any outlets.
    • Use the opening pick to lift up the eight rubber grips on the underside of the device.
    • With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
  2. HP Envy x360 m6-w105dx RAM Replacement: Schritt 2, Bild 1 von 2 HP Envy x360 m6-w105dx RAM Replacement: Schritt 2, Bild 2 von 2
    • Open the laptop and turn to the keyboard.
    • Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
    • Lift the keyboard panel from the bottom and carefully start to lift up.
    • There are ribbon cables still connected on the under side of the the keyboard. Do not pull the keyboard away from the device.
  3. HP Envy x360 m6-w105dx RAM Replacement: Schritt 3, Bild 1 von 2 HP Envy x360 m6-w105dx RAM Replacement: Schritt 3, Bild 2 von 2
    • Gently lift the keyboard up from the bottom.
    • Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
    • Do not remove the ZIF connectors by pulling on the wires, instead detach them by gently flipping up the plastic tabs located at the ends of the wiring.
    • Fully remove the keyboard from the laptop and install your new keyboard.
  4. HP Envy x360 m6-w105dx RAM Replacement, RAM: Schritt 4, Bild 1 von 3 HP Envy x360 m6-w105dx RAM Replacement, RAM: Schritt 4, Bild 2 von 3 HP Envy x360 m6-w105dx RAM Replacement, RAM: Schritt 4, Bild 3 von 3
    • Gently open the ZIF connectors and remove the ribbon cables.
    • Unscrew the five 4mm screws with the Phillips #1 screwdriver.
    • Unscrew the WLAN chip and push the chip up and out of the port.
  5. HP Envy x360 m6-w105dx RAM Replacement: Schritt 5, Bild 1 von 2 HP Envy x360 m6-w105dx RAM Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the cable connectors for the speakers.
    • Lift the motherboard up and flip towards you to disconnect an additional cable connector on the rear side.
    • Use an opening pick to pull the motherboard up on the fan side. Then pull the motherboard assembly out towards the left.
  6. HP Envy x360 m6-w105dx RAM Replacement: Schritt 6, Bild 1 von 3 HP Envy x360 m6-w105dx RAM Replacement: Schritt 6, Bild 2 von 3 HP Envy x360 m6-w105dx RAM Replacement: Schritt 6, Bild 3 von 3
    • On the underside of the motherboard, use the halberd spudger to pry up the square metal cover.
    • The metal cover is used to protect the RAM chips.
  7. HP Envy x360 m6-w105dx RAM Replacement: Schritt 7, Bild 1 von 3 HP Envy x360 m6-w105dx RAM Replacement: Schritt 7, Bild 2 von 3 HP Envy x360 m6-w105dx RAM Replacement: Schritt 7, Bild 3 von 3
    • Pull the metal retaining pins on either side of the RAM stick apart. The RAM stick will pop up.
    • Remove the RAM and insert a new one that is compatible.
    • Do not force the RAM stick or it will snap.
    • When doing a RAM replacement, make sure the correct chip is being used.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
this is the first time i’ve been on the ifixit site but thanks to my google search of this topic, I found this and it is extremely simple and helpful. I haven’t actually done this yet but am confident I can once I get the replacement ram. I need my laptop to be a portable video editing work station and the stock ram on these will run premiere pro, just very very slowly.
Tyler - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 973
