Zum Hauptinhalt wechseln
HP Flyer Red Battery Replacement
  1. HP Flyer Red Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Flyer Red Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Battery Replacement: Schritt 2, Bild 1 von 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Battery Replacement: Schritt 3, Bild 1 von 2 HP Flyer Red Battery Replacement: Schritt 3, Bild 2 von 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Battery Replacement: Schritt 4, Bild 1 von 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 4-5, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-5, Catania Spring 2016
UMASSD-CATANIA-S16S4G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 2,394
