Einleitung
This guide is helpful if you have something wrong with your hard drive and you need to replace it.
Ersatzteile
Keine Ersatzteile angegeben.
On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
The left switch is the battery unlock switch.
Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
Then take and slide the other switch to the other end of its track which will pop out the battery.
Grab the battery and pull it out of the slot.
Remove the 4mm Phillips #1 screw located towards the middle of the laptop slightly towards the right with the picture of the CD next to it.
Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
Next turn the laptop over and flip open the screen.
Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
Next lift up the keyboard gently and use the plastic opening tool to undo the ribbon wire by unclasping the ZIF (zero insertion force) connector to the laptop.
Gently slide the ribbon wire out of its slot.
After removing the keyboard close the laptop and flip it over.
Using a spudger to remove the rubber bumpers located at the top left and top right of the laptop.
Now remove both corner pieces by sliding them away from the laptop and pulling upwards.
Remove the two 4mm Phillips #1 screws located where you pulled the disk tray out of.
Now flip the laptop back over and open the screen. Remove the four 4mm Phllips #1 screws.
Using the plastic opening tool detach both ribbon cables by disconnecting both ZIF (zero insertion force) connectors on the ends.
Now pull the bracket where the screws where to right as you lift up the hard drive.
It will disconnect from the motherboard as shown.
8 weitere Nutzer haben diese Anleitung absolviert.
