Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide is a step by step instruction on how to replace your optical disc drive. You may need to do this if your laptop is not reading disks or if it is damaging them.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure your laptop is powered off. With laptop closed flip to look at the underside of the laptop.
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. The left switch is the battery unlock switch. Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
  5. Remove the 4mm Phillips #1 screw located towards the middle of the laptop slightly towards the right with the picture of the CD next to it.
    • Remove the 4mm Phillips #1 screw located towards the middle of the laptop slightly towards the right with the picture of the CD next to it.
  6. Slide the disc tray out of the its slot. Slide the disc tray out of the its slot.
    • Slide the disc tray out of the its slot.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Anthony Ciotti
714 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-5, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-5, Catania Spring 2016
UMASSD-CATANIA-S16S4G5
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 5
Insgesamt: 646
