Zum Hauptinhalt wechseln
HP Folio 13t-1000 Cooling Fan Replacement
Was du brauchst
  1. HP Folio 13t-1000 Cooling Fan Replacement, Keyboard: Schritt 1, Bild 1 von 2 HP Folio 13t-1000 Cooling Fan Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 2, Bild 1 von 3 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 2, Bild 2 von 3 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 2, Bild 3 von 3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 4, Bild 1 von 2 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 5, Bild 1 von 3 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 5, Bild 2 von 3 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 5, Bild 3 von 3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 6, Bild 1 von 3 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 6, Bild 2 von 3 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Cooling Fan Replacement, Top Hardware Cover: Schritt 7, Bild 1 von 3 HP Folio 13t-1000 Cooling Fan Replacement, Top Hardware Cover: Schritt 7, Bild 2 von 3 HP Folio 13t-1000 Cooling Fan Replacement, Top Hardware Cover: Schritt 7, Bild 3 von 3
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 8, Bild 1 von 2 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 8, Bild 2 von 2
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Cooling Fan Replacement, Cooling Fan: Schritt 9, Bild 1 von 2 HP Folio 13t-1000 Cooling Fan Replacement, Cooling Fan: Schritt 9, Bild 2 von 2
    • Use a PH1 screw head to remove the two, 3mm screws.
  10. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 10, Bild 1 von 2 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 10, Bild 2 von 2
    • Remove the connection from the fan to the motherboard by using the nylon spudger or your fingers.
  11. HP Folio 13t-1000 Cooling Fan Replacement: Schritt 11, Bild 1 von 2 HP Folio 13t-1000 Cooling Fan Replacement: Schritt 11, Bild 2 von 2
    • Remove and replace the cooling fan.
Abschluss
Josh Rollins
131 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-2, Cagle Fall 2016 Mitglied von USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 1,323
