Zum Hauptinhalt wechseln
HP G60 RAM Replacement
Was du brauchst
  1. HP G60 RAM Replacement, Battery: Schritt 1, Bild 1 von 3 HP G60 RAM Replacement, Battery: Schritt 1, Bild 2 von 3 HP G60 RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • First, you should to remove the battery to avoid electric shocks
    • Slide and unlock the battery, then, lift it
  2. HP G60 RAM Replacement, RAM cover: Schritt 2, Bild 1 von 3 HP G60 RAM Replacement, RAM cover: Schritt 2, Bild 2 von 3 HP G60 RAM Replacement, RAM cover: Schritt 2, Bild 3 von 3
    • Remove the two screws with a not too large screwdriver
    • Now lift the cover, the screws are part of the cover
  3. HP G60 RAM Replacement, Eject RAM: Schritt 3, Bild 1 von 3 HP G60 RAM Replacement, Eject RAM: Schritt 3, Bild 2 von 3 HP G60 RAM Replacement, Eject RAM: Schritt 3, Bild 3 von 3
    • Push the little aluminum locks at the top and the bottom of the ram
    • The memory will lift, then pull it
    • Make this with the another RAM slot
  4. HP G60 RAM Replacement, New RAM: Schritt 4, Bild 1 von 3 HP G60 RAM Replacement, New RAM: Schritt 4, Bild 2 von 3 HP G60 RAM Replacement, New RAM: Schritt 4, Bild 3 von 3
    • The new RAM memory should to be insert in a 45 degrees angle
    • Then, push it and the memory will lock by itself
    • Make this with the second memory
  5. HP G60 RAM Replacement, RAM cover (Again): Schritt 5, Bild 1 von 3 HP G60 RAM Replacement, RAM cover (Again): Schritt 5, Bild 2 von 3 HP G60 RAM Replacement, RAM cover (Again): Schritt 5, Bild 3 von 3
    • Insert the cover from right to left, then, screw it
    • If cover is lifted, press it softly and secure it
Ziellinie
5 weitere Nutzer:innen haben diese Anleitung absolviert.
jimenezser
3.848 Reputation
4 Anleitungen geschrieben
Ein Kommentar
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 6,035
