Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
First, remove the battery to avoid electric shock
Slide and unlock the battery, then lift it
Now, you should to remove the Wi-Fi card cover
Remove this screw
Lift the cover
The Wi-Fi card is locked, but you should to change that.
Remove this two little screws.
Pull the Wi-Fi card.
Pull carefully both cables from the Wi-Fi card, it requires a little strength
Now it's time to put the new Wi-Fi card
Connect both plugs, the cable with white tag, at the left of the Wi-Fi card, the green one, at the right plug
The Wi-Fi card already has the power plugs, now it's time to the data plug
Insert the Wi-Fi card in a 45 degrees angle
Now press it and screw it
For finish, reassemble the cover
If the cover is still lifted, press softly until you hear a click
5 weitere Nutzer haben diese Anleitung absolviert.
4 Kommentare
If the button that turns blue when I start my computer stays orange does that mean I need to install a new wifi card?
Hi frnd just want to know ur hp laptop button was not working it stayed orange thn what did u do? U changed wifi card or button plz reply me i have same condition can u ans me on my mobile whatsapp plz +85254077440
