Zum Hauptinhalt wechseln
HP G60-443CL Battery Replacement
Was du brauchst
  1. HP G60-443CL Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside down where the headphone and auxiliary jack are facing you.
  2. HP G60-443CL Battery Replacement: Schritt 2, Bild 1 von 1
    • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
  3. HP G60-443CL Battery Replacement: Schritt 3, Bild 1 von 1
    • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
  4. HP G60-443CL Battery Replacement: Schritt 4, Bild 1 von 1
    • The battery can then be pulled out of its compartment by hand.
Abschluss
Alora Allen
101 Reputation
1 Anleitung geschrieben
Baylor, Team S8-G7, Johnson Fall 2017 Mitglied von Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 314
