Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
You will learn how to remove your full or defective hard drive and replace it with another. It may be beneficial to watch a video of a hard drive being taken out to familiarize yourself with this step, since there was no hard drive to take out on this example.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. Place your index finger on the ridged tab. Place your index finger on the ridged tab.
    • Place your index finger on the ridged tab.
  3. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  4. Apply moderate pressure to the tab and slide it to the right.
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  5. Remove the 5cm screws with a #00 Phillips screwdriver. Take the cover off.
    • Remove the 5cm screws with a #00 Phillips screwdriver.
    • Take the cover off.
  6. Remove the following .5cm screws with a #0 Phillips screwdriver. Slide the hard drive cover to the right with light-medium force. Slide the hard drive cover to the right with light-medium force.
    • Remove the following .5cm screws with a #0 Phillips screwdriver.
    • Slide the hard drive cover to the right with light-medium force.
  7. Pull up on the little black tab on the hard drive case to remove it.
    • Pull up on the little black tab on the hard drive case to remove it.
    • From here you will be able to carefully slide your hard drive out.
Abschluss
Dominic DeSantis
724 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 4-5, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 89
