Einleitung
This guide will show users how to replace the CD/DVD Drive for the device. You will need a Phillips #1 screwdriver and a plastic prying tool.
Was du brauchst
Turn the device over so the bottom is facing up.
Slide the battery release to the left until you hear a click.
Once you hear a click, the battery will have been released from the battery compartment.
Find the hard drive compartment with two Phillips head screws.
Use the PH1 screwdriver to loosen and remove both screws.
Gently remove the hard drive compartment.
On the far left of the hard drive compartment, find the Phillips head screw.
Remove the Phillips head screw with the PH1 screwdriver.
Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
Carefully pry the CD/DVD drive open.
Slide the CD/DVD drive out once it is pried open.
