Zum Hauptinhalt wechseln
HP G62 347NR Keyboard Replacement
Was du brauchst
  1. HP G62 347NR Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Keyboard Replacement: Schritt 3, Bild 1 von 2 HP G62 347NR Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Keyboard Replacement: Schritt 4, Bild 1 von 2 HP G62 347NR Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Keyboard Replacement: Schritt 5, Bild 1 von 2 HP G62 347NR Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Keyboard Replacement: Schritt 6, Bild 1 von 2 HP G62 347NR Keyboard Replacement: Schritt 6, Bild 2 von 2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Keyboard Replacement: Schritt 7, Bild 1 von 2 HP G62 347NR Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
McKenzi Morris
511 Reputation
3 Anleitungen geschrieben
Texas Tech, Team 6-1, Bennett Fall 2016 Mitglied von Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 2,766
