Zum Hauptinhalt wechseln
HP G62-144DX Hard Drive Replacement
Was du brauchst
  1. HP G62-144DX Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP G62-144DX Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Hard Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 3 HP G62-144DX Hard Drive Replacement, Hard Drive: Schritt 2, Bild 2 von 3 HP G62-144DX Hard Drive Replacement, Hard Drive: Schritt 2, Bild 3 von 3
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP G62-144DX Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP G62-144DX Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
Abschluss
Cameron Moran
623 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S4-G8, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S4-G8, Julie Fall 2017
UMASSD-JULIE-F17S4G8
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 315
