Einleitung
The keyboard may not be working for a variety of reasons and may need to be replaced.
Was du brauchst
Slide the lock to the right, located slightly above the battery location.
While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
Gently use a plastic opening tool to remove the panel.
Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
Flip the laptop so the top is facing up again and open the cover.
Use a metal spudger to pry the keyboard up and pull it back.
2 weitere Personen haben diese Anleitung absolviert.
