Zum Hauptinhalt wechseln
HP G62-144DX RAM Replacement
Was du brauchst
  1. HP G62-144DX RAM Replacement, Battery: Schritt 1, Bild 1 von 2 HP G62-144DX RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX RAM Replacement, RAM: Schritt 2, Bild 1 von 3 HP G62-144DX RAM Replacement, RAM: Schritt 2, Bild 2 von 3 HP G62-144DX RAM Replacement, RAM: Schritt 2, Bild 3 von 3
    • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but will come loose from the body of the laptop.
    • Use a plastic opening tool to gently pry the panel free from the laptop.
  3. HP G62-144DX RAM Replacement: Schritt 3, Bild 1 von 3 HP G62-144DX RAM Replacement: Schritt 3, Bild 2 von 3 HP G62-144DX RAM Replacement: Schritt 3, Bild 3 von 3
    • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
    • After the RAM module pops up, gently pull in out from the computer.
    • Repeat for the second RAM module.
Abschluss
Cameron Moran
623 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S4-G8, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S4-G8, Julie Fall 2017
UMASSD-JULIE-F17S4G8
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 321
