Einleitung
If your battery is not working and you need to take it out, do the following steps to remove it properly.
Was du brauchst
Slide the lock to the right, located slightly above the battery location.
While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Fast fertig!
Abschluss
