Zum Hauptinhalt wechseln
HP G62-223CL Optical Drive Replacement
Was du brauchst
  1. HP G62-223CL Optical Drive Replacement, Battery Removal: Schritt 1, Bild 1 von 2 HP G62-223CL Optical Drive Replacement, Battery Removal: Schritt 1, Bild 2 von 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 1
    • Locate two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Locate the 6 mm Phillips head screw to the left of the hard drive.
    • Use a Phillips #0 screwdriver to remove the screw.
  5. HP G62-223CL Optical Drive Replacement: Schritt 5, Bild 1 von 2 HP G62-223CL Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
    • Apply enough pressure to loosen the optical drive.
    • The optical drive can then be removed by hand.
Abschluss
Garret Layton
669 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-4, Sullivan Winter 2015 Mitglied von USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,239
