Einleitung
This guide will show the user how to remove the optical drive.
Was du brauchst
Turn the device over to expose the bottom of the device.
Slide the battery release all the way to the left.
There will be a click and the battery will be released from its compartment.
Locate two Phillips head retaining screws which secure the hard drive compartment.
Use a Phillips #0 screwdriver to loosen the retaining screws.
Remove the panel covering the compartment.
Locate the 6 mm Phillips head screw to the left of the hard drive.
Use a Phillips #0 screwdriver to remove the screw.
Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
Apply enough pressure to loosen the optical drive.
The optical drive can then be removed by hand.
