Einleitung
This guide will show the user how to remove the RAM modules.
Was du brauchst
Turn the device over to expose the bottom of the device.
Slide the battery release all the way to the left.
There will be a click and the battery will be released from its compartment.
Locate three Phillips head retaining screws which secure RAM compartment.
Use a Phillips #0 screwdriver to loosen the screws.
Remove the panel covering the compartment.
Use the tip of a screw driver to press the release clips away from the RAM module.
Once the second clip is released, the module will automatically pop up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
