Einleitung
This guide will show the user how to remove the wireless card.
Was du brauchst
Turn the device over to expose the bottom of the device.
Slide the battery release all the way to the left.
There will be a click and the battery will be released from its compartment.
Locate three Phillips head retaining screws which secure the compartment.
Use a Phillips #0 screwdriver to loosen the retaining screws.
Remove the panel covering the compartment.
Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
