Einleitung
This guide will explain the process to replace the RAM in the HP G62-234DX.
Was du brauchst
While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
Use a Phillips #0 screwdriver to remove three screws from the back panel.
Carefully pull the panel off of the back of the laptop to reveal the RAM sticks.
Two clips secure the RAM stick in place, one on each side. Using your fingers, spread the clips away from the RAM stick.
Lift the RAM stick to an angle of about 30 degrees and slide it out.
