Zum Hauptinhalt wechseln
HP G71t-300 Cooling Fan Replacement
Was du brauchst
  1. HP G71t-300 Cooling Fan Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP G71t-300 Cooling Fan Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP G71t-300 Cooling Fan Replacement, Keyboard: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
    • Turn off the computer and remove the charger from the charging port.
    • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
  2. HP G71t-300 Cooling Fan Replacement: Schritt 2, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the four screws from the indicated cover.
    • Gently lift and remove the cover.
  3. HP G71t-300 Cooling Fan Replacement: Schritt 3, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 3, Bild 2 von 2
    • Remove the five 6mm screws with the Phillips #0 screwdriver.
  4. HP G71t-300 Cooling Fan Replacement: Schritt 4, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Pry the keyboard off with a spudger. Be careful not to apply too much pressure and damage any components.
  5. HP G71t-300 Cooling Fan Replacement: Schritt 5, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the clip attaching the keyboard wiring to the motherboard. Lift and remove the keyboard.
  6. HP G71t-300 Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 1 von 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 2 von 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the 6mm screw from the top panel.
    • Gently lift and remove the panel. Use a metal spudger if the it seems set in place.
  7. HP G71t-300 Cooling Fan Replacement: Schritt 7, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the 6mm screw for the Wi-Fi module cover.
    • Remove the cover.
  8. HP G71t-300 Cooling Fan Replacement: Schritt 8, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 8, Bild 2 von 2
    • Remove all fourteen 6mm screws using a Phillips #0 screwdriver.
  9. HP G71t-300 Cooling Fan Replacement: Schritt 9, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 9, Bild 2 von 2
    • Partially separate the two panels until connectors are visible.
    • Unclip the wires that attach the trackpad module to the motherboard.
  10. HP G71t-300 Cooling Fan Replacement: Schritt 10, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 10, Bild 2 von 2
    • Remove the five highlighted screws using a Phillips #0 screwdriver.
  11. HP G71t-300 Cooling Fan Replacement: Schritt 11, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 11, Bild 2 von 2
    • Disconnect the five cables by gently pulling them from their slots.
  12. HP G71t-300 Cooling Fan Replacement: Schritt 12, Bild 1 von 2 HP G71t-300 Cooling Fan Replacement: Schritt 12, Bild 2 von 2
    • Press a metal spudger between the VGA port and the plastic housing to pry up the motherboard.
    • Remove the motherboard and turn it so that the fan is facing upward.
  13. HP G71t-300 Cooling Fan Replacement: Schritt 13, Bild 1 von 3 HP G71t-300 Cooling Fan Replacement: Schritt 13, Bild 2 von 3 HP G71t-300 Cooling Fan Replacement: Schritt 13, Bild 3 von 3
    • Use a Phillips #0 screwdriver to loosen the three screws attaching the heatsink to the motherboard.
    • Remove the heatsink and fan assembly by unclipping the fan from the motherboard.
Abschluss
Rohan Mathew
513 Reputation
5 Anleitungen geschrieben
UC Davis, Team 2-3, Oliver Fall 2016 Mitglied von UC Davis, Team 2-3, Oliver Fall 2016
UCD-OLIVER-F16S2G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 221
