Zum Hauptinhalt wechseln
HP G71t-400 WiFi Card Replacement
Was du brauchst
  1. HP G71t-400 WiFi Card Replacement, WiFi Card: Schritt 1, Bild 1 von 3 HP G71t-400 WiFi Card Replacement, WiFi Card: Schritt 1, Bild 2 von 3 HP G71t-400 WiFi Card Replacement, WiFi Card: Schritt 1, Bild 3 von 3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 WiFi Card Replacement: Schritt 2, Bild 1 von 3 HP G71t-400 WiFi Card Replacement: Schritt 2, Bild 2 von 3 HP G71t-400 WiFi Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the only circled screw.
    • Lift and remove the cover exposing the WiFi card.
  3. HP G71t-400 WiFi Card Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the two wires attached. Making note to where each wire was connected for easy install.
    • Extract the WiFi card.
Abschluss
UMass Dartmouth, Team S1-G5, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G5, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G5
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 88
