Zum Hauptinhalt wechseln
HP G72 Memory Module Replacement
Was du brauchst
  1. HP G72 Memory Module Replacement, Memory Module: Schritt 1, Bild 1 von 3 HP G72 Memory Module Replacement, Memory Module: Schritt 1, Bild 2 von 3 HP G72 Memory Module Replacement, Memory Module: Schritt 1, Bild 3 von 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
    • Loosen the three Phillips M2.5×6.0 captive screws that secure the memory module compartment cover.
  2. HP G72 Memory Module Replacement: Schritt 2, Bild 1 von 3 HP G72 Memory Module Replacement: Schritt 2, Bild 2 von 3 HP G72 Memory Module Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool (or equivalent) to lift the back side of the cover. Small tabs hold the cover in place. Firmly pull up on the cover to release the tabs.
    • Remove the cover
    • Spread the retaining tabs on each side of the memory module slot to release the memory module. Remove the module as needed
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
oldturkey03
782.366 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
541 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 2,487
