Was du brauchst
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Locate the slider under the right side of the battery.
Using your thumb, slide it all the way to the left until the front of the battery lifts up.
With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
Remove the three 4mm screws using Phillips #1 screw driver.
Remove the four 6mm screws using Phillips #1 screw driver.
Remove the two 3mm screws using Phillips #1 screw driver.
Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
Remove the chrome keyboard cover.
Lift the black tab using the plastic opening tool.
Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
Flip over the device so that the bottom side is facing up.
Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
3 weitere Personen haben diese Anleitung absolviert.
