Zum Hauptinhalt wechseln
HP HDX 16-1160US Wifi Card Replacement
Was du brauchst
  1. HP HDX 16-1160US Wifi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Wifi Card Replacement: Schritt 2, Bild 1 von 3 HP HDX 16-1160US Wifi Card Replacement: Schritt 2, Bild 2 von 3 HP HDX 16-1160US Wifi Card Replacement: Schritt 2, Bild 3 von 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Wifi Card Replacement: Schritt 3, Bild 1 von 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US Wifi Card Replacement, Wifi Card: Schritt 4, Bild 1 von 2 HP HDX 16-1160US Wifi Card Replacement, Wifi Card: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
    • The 6mm screw will remain in the Wi-Fi card panel and will not fall out.
    • Lift off the Wi-Fi card panel off using the opposite hand.
  5. HP HDX 16-1160US Wifi Card Replacement: Schritt 5, Bild 1 von 2 HP HDX 16-1160US Wifi Card Replacement: Schritt 5, Bild 2 von 2
    • Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
  6. HP HDX 16-1160US Wifi Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 4mm screws with the Phillips #1 screw driver.
  7. HP HDX 16-1160US Wifi Card Replacement: Schritt 7, Bild 1 von 1
    • Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
    • Using the opposite hand, pull the Wi-Fi card to the left.
    • Do not lift the Wi-Fi card straight up, this will damage or break the Wi-Fi card.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Marshall Reid
527 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-38, Maness Spring 2014 Mitglied von Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 1,138
