Zum Hauptinhalt wechseln
HP LaserJet P1102w Drive Belt Replacement
Was du brauchst
  1. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: Schritt 1, Bild 1 von 3 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: Schritt 1, Bild 2 von 3 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: Schritt 1, Bild 3 von 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Drive Belt Replacement: Schritt 2, Bild 1 von 2 HP LaserJet P1102w Drive Belt Replacement: Schritt 2, Bild 2 von 2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Drive Belt Replacement: Schritt 3, Bild 1 von 2 HP LaserJet P1102w Drive Belt Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Drive Belt Replacement: Schritt 4, Bild 1 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 4, Bild 2 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Drive Belt Replacement: Schritt 5, Bild 1 von 2 HP LaserJet P1102w Drive Belt Replacement: Schritt 5, Bild 2 von 2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Drive Belt Replacement: Schritt 6, Bild 1 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 6, Bild 2 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Drive Belt Replacement: Schritt 7, Bild 1 von 2 HP LaserJet P1102w Drive Belt Replacement: Schritt 7, Bild 2 von 2
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: Schritt 8, Bild 1 von 3 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: Schritt 8, Bild 2 von 3 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: Schritt 8, Bild 3 von 3
    • Refer to the prerequisite guide to take off the front panel off.
    • With a #1 Phillips screwdriver remove only the top Phillips 60mm screw.
    • With the spudger pry the side panel off. There will be four flanges to unhitch.
  9. HP LaserJet P1102w Drive Belt Replacement: Schritt 9, Bild 1 von 2 HP LaserJet P1102w Drive Belt Replacement: Schritt 9, Bild 2 von 2
    • With side panel removed, there will be four Phillips 60mm screws to unscrew using a #1 Phillips screwdriver.
  10. HP LaserJet P1102w Drive Belt Replacement: Schritt 10, Bild 1 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 10, Bild 2 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 10, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove top two big gears using tweezers.
    • Take note of gear placement.
  11. HP LaserJet P1102w Drive Belt Replacement: Schritt 11, Bild 1 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 11, Bild 2 von 3 HP LaserJet P1102w Drive Belt Replacement: Schritt 11, Bild 3 von 3
    • With the #1 Phillips screwdriver remove the 60mm Phillips screw holding the belt tension-er.
    • With the screw removed, pull tension-er out.
    • Use tweezers to remove the loose drive belt.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Jerome Etten
730 Reputation
4 Anleitungen geschrieben
UW Stout, Team S6-G4, Ogden Fall 2018 Mitglied von UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
the tight side panel clips make this a difficult procedure, so take care both disassembling and assembling, for example make sure the power button is aligned with the level components behind before you push to clip the front home, as misalignment can break or dislocate internal parts.
Peter Taffs - Antwort
Que dois je faire si mon imprimante fait beaucoup de bruit en imprimant et que la totalité de feuille imprimée ne sort pas?
anelka VILPIGUE - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 52
Letzte 30 Tage: 96
Insgesamt: 3,322
