Zum Hauptinhalt wechseln
HP LaserJet P1102w Motherboard Replacement
Was du brauchst
  1. HP LaserJet P1102w Motherboard Replacement, Left Side Panel: Schritt 1, Bild 1 von 3 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: Schritt 1, Bild 2 von 3 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: Schritt 1, Bild 3 von 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Motherboard Replacement: Schritt 2, Bild 1 von 2 HP LaserJet P1102w Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Motherboard Replacement: Schritt 3, Bild 1 von 2 HP LaserJet P1102w Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Motherboard Replacement: Schritt 4, Bild 1 von 3 HP LaserJet P1102w Motherboard Replacement: Schritt 4, Bild 2 von 3 HP LaserJet P1102w Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Motherboard Replacement: Schritt 5, Bild 1 von 2 HP LaserJet P1102w Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Motherboard Replacement: Schritt 6, Bild 1 von 3 HP LaserJet P1102w Motherboard Replacement: Schritt 6, Bild 2 von 3 HP LaserJet P1102w Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Motherboard Replacement: Schritt 7, Bild 1 von 2 HP LaserJet P1102w Motherboard Replacement: Schritt 7, Bild 2 von 2
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 3 HP LaserJet P1102w Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 3 HP LaserJet P1102w Motherboard Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Remove three #1 Phillips 6mm screws with the #1 Phillips screwdriver.
  9. HP LaserJet P1102w Motherboard Replacement: Schritt 9, Bild 1 von 3 HP LaserJet P1102w Motherboard Replacement: Schritt 9, Bild 2 von 3 HP LaserJet P1102w Motherboard Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using a pair of blunt nose tweezers, disconnect both ribbon wires.
    • With both ribbon wires removed we can lift the motherboard out of its housing.
    • There is a little black notch holding the motherboard down by the thumb in the final picture.
    • Be careful pulling, as ribbon wires are very fragile.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Jerome Etten
730 Reputation
4 Anleitungen geschrieben
UW Stout, Team S6-G4, Ogden Fall 2018 Mitglied von UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 48
Insgesamt: 1,968
