Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide is used as a prereq to other guides.
Ersatzteile
Keine Ersatzteile angegeben.
  1. If present, remove the large piece of black adhesive film covering the area around the fan.
    • If present, remove the large piece of black adhesive film covering the area around the fan.
  2. If present, remove the pieces of black cloth tape securing the antenna cables to the motherboard. If present, remove the pieces of black cloth tape securing the antenna cables to the motherboard.
    • If present, remove the pieces of black cloth tape securing the antenna cables to the motherboard.
  3. Use the flat end of a spudger or your fingers to disconnect the following cables: Speaker cable
    • Use the flat end of a spudger or your fingers to disconnect the following cables:
    • Speaker cable
    • Microphone cable
    • Fan cable
    • Power cable
    • Display data cable
    • Do not lift the connectors up as you disconnect them from the motherboard. Push the connectors out of their sockets parallel to the face of the logic board toward the display assembly. Use extra care when disconnecting the display data cable, as its connector and socket are fragile.
  4. Remove the 2.5 mm Phillips screw securing the power switch lever to the lower case. Use a pair of tweezers or your fingers to lift the power switch lever out of the Mini 1000.
    • Remove the 2.5 mm Phillips screw securing the power switch lever to the lower case.
    • Use a pair of tweezers or your fingers to lift the power switch lever out of the Mini 1000.
  5. Remove the 2.5 mm Phillips screw securing the wireless on/off switch lever to the lower case. Use tweezers or your fingers to remove the wireless on/off switch lever from the Mini 1000.
    • Remove the 2.5 mm Phillips screw securing the wireless on/off switch lever to the lower case.
    • Use tweezers or your fingers to remove the wireless on/off switch lever from the Mini 1000.
  6. Remove the two 3 mm Phillips screws securing the USB bracket to the lower case. Pry up the USB bracket and remove it from the motherboard.
    • Remove the two 3 mm Phillips screws securing the USB bracket to the lower case.
    • Pry up the USB bracket and remove it from the motherboard.
  7. Remove the single 4.5 mm Phillips screw securing the motherboard to the lower case near the fan.
    • Remove the single 4.5 mm Phillips screw securing the motherboard to the lower case near the fan.
  8. Carefully lift the motherboard from its right edge and remove it from the lower case, minding any cables that may get caught. Carefully lift the motherboard from its right edge and remove it from the lower case, minding any cables that may get caught.
    • Carefully lift the motherboard from its right edge and remove it from the lower case, minding any cables that may get caught.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 54
