Einleitung
Use this guide to replace or upgrade the single PC2-4200 RAM stick on your Mini 1000.
Was du brauchst
With the case closed, place the Mini 1000 top-side down on a flat surface.
Push both of the battery release latches toward each other.
Lift the battery out of the Mini 1000 from the edge closest to the release latches.
Before proceeding, slide the right battery release latch to the unlocked position nearest the center of the computer.
Use the tip of a spudger to slide the RAM compartment cover release latch away from the center of the computer.
Use your fingers to simultaneously pull both RAM retaining arms away from the center of the RAM chip.
Pull the RAM chip out of its socket and remove it from the Mini 1000.
2 weitere Personen haben diese Anleitung absolviert.
