Was du brauchst
Power off the laptop before trying to remove the battery.
Turn the laptop upside down, and locate the sliding tabs on the battery.
Slide both tabs in an inward direction, then slide the battery away from the laptop.
To remove the bottom cover pull the orange tab to the right until it clicks.
Carefully disconnect the clips as you lift the bottom cover.
Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
Pull the hard drive out of the laptop.
To reinstall a new or old hard drive, follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
