Zum Hauptinhalt wechseln
HP Mini 110-3131dx Touchpad Replacement
Was du brauchst
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Touchpad Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  2. HP Mini 110-3131dx Touchpad Replacement: Schritt 3, Bild 1 von 3 HP Mini 110-3131dx Touchpad Replacement: Schritt 3, Bild 2 von 3 HP Mini 110-3131dx Touchpad Replacement: Schritt 3, Bild 3 von 3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  3. HP Mini 110-3131dx Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
  4. HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: Schritt 5, Bild 1 von 2 HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: Schritt 5, Bild 2 von 2
    • Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
    • Be sure to keep track of which screws go where as they are not all the same size.
    • Flip the laptop over and remove the six black screws.
  5. HP Mini 110-3131dx Touchpad Replacement: Schritt 6, Bild 1 von 2 HP Mini 110-3131dx Touchpad Replacement: Schritt 6, Bild 2 von 2
    • Using your fingernail or the iFixit opening tool, flip the black tab up to release the ribbon cable that connects the touchpad and motherboard.
    • Disconnect the red and black wires from the motherboard on the left-hand side of the bezel using your fingernail or iFixit opening tool.
  6. HP Mini 110-3131dx Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Lift the keyboard bezel from the back end and slide the iFixit opening tool around the perimeter of the bezel until it is fully released.
  7. HP Mini 110-3131dx Touchpad Replacement, Touchpad: Schritt 8, Bild 1 von 3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: Schritt 8, Bild 2 von 3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: Schritt 8, Bild 3 von 3
    • Turn the keyboard so that the touchpad is close to you.
    • Detach the ribbon cable from the connector on the touchpad circuit board using your fingernail or an opening tool.
    • Remove the four 2.9 mm screws from the bracket using a Phillips #0 screwdriver.
    • Remove the touchpad from the top of the keyboard bezel on the touch-sensitive side.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
aarondcollege
1.297 Reputation
10 Anleitungen geschrieben
USF Tampa, Team 2-4, Cagle Fall 2016 Mitglied von USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 611
