Einleitung
If your hard drive is broken or you just want to upgrade, this guide will walk you through the steps for replacing the hard drive.
Was du brauchst
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
Lift the hard drive cage by pulling the tape upward.
Start by pulling the tape from the side with the keyboard symbol.
Remove the four 4.0 mm screws on both sides of the cage using a Phillips #1 screw driver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
