Zum Hauptinhalt wechseln
HP Mini 110-3735dx Keyboard Replacement
Was du brauchst
  1. HP Mini 110-3735dx Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 HP Mini 110-3735dx Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 HP Mini 110-3735dx Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Mini 110-3735dx Keyboard Replacement: Schritt 2, Bild 2 von 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Keyboard Replacement, Backcover: Schritt 3, Bild 1 von 3 HP Mini 110-3735dx Keyboard Replacement, Backcover: Schritt 3, Bild 2 von 3 HP Mini 110-3735dx Keyboard Replacement, Backcover: Schritt 3, Bild 3 von 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 HP Mini 110-3735dx Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Mini 110-3735dx Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Keyboard Replacement: Schritt 6, Bild 1 von 2 HP Mini 110-3735dx Keyboard Replacement: Schritt 6, Bild 2 von 2
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Mini 110-3735dx Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Keyboard Replacement: Schritt 9, Bild 1 von 2 HP Mini 110-3735dx Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Keyboard Replacement: Schritt 10, Bild 1 von 2 HP Mini 110-3735dx Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Gently pull the keyboard cable from the socket.
Abschluss
UMass Dartmouth, Team 4-1, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-1, Catania Spring 2016
UMASSD-CATANIA-S16S4G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 701
