Einleitung
If your computer is running slow, has had blue screen of death, or you want to upgrade your HP Mini, follow this guide for replacing your RAM.
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
Push the two white holders holding the RAM outward until it points upwards at about a 45 degree angle.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
