Zum Hauptinhalt wechseln
HP Mini 110-3735dx Screen Replacement
Was du brauchst
  1. HP Mini 110-3735dx Screen Replacement, Battery: Schritt 1, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement, Battery: Schritt 1, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Screen Replacement: Schritt 2, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 2, Bild 2 von 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Screen Replacement, Backcover: Schritt 3, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement, Backcover: Schritt 3, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement, Backcover: Schritt 3, Bild 3 von 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Screen Replacement, Keyboard: Schritt 4, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Screen Replacement: Schritt 5, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 5, Bild 2 von 2
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Screen Replacement: Schritt 6, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 6, Bild 2 von 2
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Screen Replacement: Schritt 7, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 7, Bild 2 von 2
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Screen Replacement: Schritt 8, Bild 1 von 1
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Screen Replacement: Schritt 9, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 9, Bild 2 von 2
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Screen Replacement: Schritt 10, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 10, Bild 2 von 2
    • Gently pull the keyboard cable from the socket.
  11. HP Mini 110-3735dx Screen Replacement, Hard Drive Cage: Schritt 11, Bild 1 von 1
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  12. HP Mini 110-3735dx Screen Replacement: Schritt 12, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 12, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 12, Bild 3 von 3
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  13. HP Mini 110-3735dx Screen Replacement: Schritt 13, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 13, Bild 2 von 2
    • Unplug the cable connecting to the hard drive.
  14. HP Mini 110-3735dx Screen Replacement, Screen: Schritt 14, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement, Screen: Schritt 14, Bild 2 von 2
    • Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
  15. HP Mini 110-3735dx Screen Replacement: Schritt 15, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 15, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 15, Bild 3 von 3
    • Lift the two black holders upward located next to the socket for the keyboard close to the tracked pad.
  16. HP Mini 110-3735dx Screen Replacement: Schritt 16, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 16, Bild 2 von 2
    • Remove the two connectors for the motherboard from their sockets.
  17. HP Mini 110-3735dx Screen Replacement: Schritt 17, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 17, Bild 2 von 2
    • Close the laptop by bringing the screen down.
    • Flip the laptop over to the other side.
  18. HP Mini 110-3735dx Screen Replacement: Schritt 18, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 18, Bild 2 von 2
    • Remove the 6 5.0 mm screws holding the back plate together using a Phillips #1 screw driver.
  19. HP Mini 110-3735dx Screen Replacement: Schritt 19, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 19, Bild 2 von 2
    • Remove the 2 3.0 mm screw head holding the plastic piece in place using a Phillips #1 screw driver.
    • Located on the left and right side where the battery was removed.
  20. HP Mini 110-3735dx Screen Replacement: Schritt 20, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 20, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 20, Bild 3 von 3
    • Pull the black plastic pieces that the screws was holding inward.
    • The pieces are located on the left and right corners connecting the bottom and top of the HP Mini.
  21. HP Mini 110-3735dx Screen Replacement: Schritt 21, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 21, Bild 2 von 2
    • Flip the laptop back over.
    • Open it by lifting the screeen.
  22. HP Mini 110-3735dx Screen Replacement: Schritt 22, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 22, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 22, Bild 3 von 3
    • Right next to the previous plastic piece, remove the other two plastic pieces.
    • This may be difficult to come off. Tilt the screen back and forth to help loosen the piece.
  23. HP Mini 110-3735dx Screen Replacement: Schritt 23, Bild 1 von 1
    • Using the plastic prying tool, pry the front plate of the bottom part of your HP Mini.
    • Start along the speaker grill near the touch pad, and move along the sides.
  24. HP Mini 110-3735dx Screen Replacement: Schritt 24, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 24, Bild 2 von 2
    • Lift up the front plate where the keyboard was.
  25. HP Mini 110-3735dx Screen Replacement: Schritt 25, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 25, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 25, Bild 3 von 3
    • Remove the display cable from the motherboard located on the top left corner under where the keyboard was by pulling on the black tab.
    • Move the cable.
  26. HP Mini 110-3735dx Screen Replacement: Schritt 26, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 26, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 26, Bild 3 von 3
    • Remove the webcam cables from the motherboard.
    • Located on the back side of the laptop in the bottom left corner.
  27. HP Mini 110-3735dx Screen Replacement: Schritt 27, Bild 1 von 1
    • Flip over the computer, and open the laptop.
    • Lift up the front plate on the top right corner.
  28. HP Mini 110-3735dx Screen Replacement: Schritt 28, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 28, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 28, Bild 3 von 3
    • Pull the cables for the web cam out using tweezers.
  29. HP Mini 110-3735dx Screen Replacement: Schritt 29, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 29, Bild 2 von 2
    • Remove the 2 3.0 mm screws on both sides of the bottom of the display using a Phillips #1 screwdriver.
  30. HP Mini 110-3735dx Screen Replacement: Schritt 30, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 30, Bild 2 von 2
    • Remove the black plastic piece that the screw was holding on both sides.
    • This will reveal another screw.
  31. HP Mini 110-3735dx Screen Replacement: Schritt 31, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 31, Bild 2 von 2
    • Remove the 2 3.0 mm screws on both sides using a Phillips #1 screw driver.
    • When removing, keep hold of the screen to make sure it doesn't fall.
  32. HP Mini 110-3735dx Screen Replacement: Schritt 32, Bild 1 von 1
    • Pry the front plate using the plastic opening tool by pushing along the border of the front and back plate.
    • Make sure to pry from the sides, top and bottom as the corners will come undone themselves.
  33. HP Mini 110-3735dx Screen Replacement: Schritt 33, Bild 1 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 33, Bild 2 von 3 HP Mini 110-3735dx Screen Replacement: Schritt 33, Bild 3 von 3
    • Remove the front plate.
    • Pull the cables through the holes.
  34. HP Mini 110-3735dx Screen Replacement: Schritt 34, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 34, Bild 2 von 2
    • Remove the 4 4.0 mm screws holding the screen in place using a Phillips #1 screw driver.
  35. HP Mini 110-3735dx Screen Replacement: Schritt 35, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 35, Bild 2 von 2
    • Lift the screen up.
  36. HP Mini 110-3735dx Screen Replacement: Schritt 36, Bild 1 von 2 HP Mini 110-3735dx Screen Replacement: Schritt 36, Bild 2 von 2
    • Under the screen, peel off the tape near the cable completely, so you can see the socket for the cable.
Abschluss
UMass Dartmouth, Team 4-1, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-1, Catania Spring 2016
UMASSD-CATANIA-S16S4G1
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
Icela Ross - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 778
