Zum Hauptinhalt wechseln
HP Mini 210-1199DX CMOS Battery Replacement
Was du brauchst
  1. HP Mini 210-1199DX CMOS Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Mini 210-1199DX CMOS Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX CMOS Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX CMOS Battery Replacement, Bottom Cover: Schritt 3, Bild 1 von 1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX CMOS Battery Replacement: Schritt 4, Bild 1 von 3 HP Mini 210-1199DX CMOS Battery Replacement: Schritt 4, Bild 2 von 3 HP Mini 210-1199DX CMOS Battery Replacement: Schritt 4, Bild 3 von 3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX CMOS Battery Replacement: Schritt 5, Bild 1 von 1
    • Pull the case off of the device
  6. HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: Schritt 6, Bild 1 von 2 HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: Schritt 6, Bild 2 von 2
    • Simply pull the small black ribbon off of the battery with either your finger or a pair of tweezers.
  7. HP Mini 210-1199DX CMOS Battery Replacement: Schritt 7, Bild 1 von 2 HP Mini 210-1199DX CMOS Battery Replacement: Schritt 7, Bild 2 von 2
    • Using the spudger, carefully pop the battery out of the right side as seen in the picture.
    • To reinstall, carefully place slide the battery back into place with the positive side facing upwards.
Abschluss
Texas Tech, Team S46-G3, Bennett Spring 2017 Mitglied von Texas Tech, Team S46-G3, Bennett Spring 2017
TTU-BENNETT-S17S46G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 681
