Einleitung
This guide will show you how to replace missing or broken keys from the keyboard of a HP Mini 210-1199DX.
Was du brauchst
Locate the broken key(s) and make sure there's nothing blocking it or jammed in the slots. Insert the key into the key slot.
Take a clean cotton swab and make sure to clean out both the key itself alone with the key slot. Remove anything that may be jamming or interfering with the key.
With the key slot clear, press the key into the slot firmly. Upon hearing a click press it a few times to confirm that it is fully attached.
