Einleitung
In this guide you'll be able to locate and remove or change out the Wireless Card of the HP Mini 210-1199DX.
Was du brauchst
Unplug the netbook.
Secure the netbook in a upright position.
Slide the plastic battery latch that secures it into the netbook.
Keep thumb secure on the right tab as you begin to remove the battery.
Press down on the two orange buttons to release.
If the case does not pop off, begin to use Spudger to pry the case off the back.
Place the spudger on corners and openings in order to begin removal of the back.
Continue this on all corner until the case comes fully off of the back.
With fingers or tweezers, carefully pull the black and white wire connectors from their sockets and move them to the side.
With a Phillip's Screwdriver, firmly but slowly remove the two screws from the top of the wireless card.
Be careful not to strip the nail head.
