Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to remove the battery and the back cover of your laptop in order to repair or install new parts.
  1. Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. The battery locking latch is on the bottom right corner, slide it inward to unlock the battery. Slide the battery release latch inwards. Pull the battery towards you to remove it.
    • The battery locking latch is on the bottom right corner, slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. Slide the service access cover release lever to the right. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. Orientate the computer as shown in the picture.
    • Orientate the computer as shown in the picture.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sean Kuster
82 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-23, Amido Fall 2012 Mitglied von Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 1,340
