Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to remove and install a new hard drive.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. The battery locking latch is on the bottom right corner, slide it inward to unlock the battery. Slide the battery release latch inwards. Pull the battery towards you to remove it.
    • The battery locking latch is on the bottom right corner, slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. Slide the service access cover release lever to the right. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. Orientate the computer as shown in the picture.
    • Orientate the computer as shown in the picture.
  5. Locate the HP product sticker, a black square sticker covered with product details, at the top of the computer. Pull off the HP product sticker, starting at the top right corner and pulling diagonally down towards the bottom right. Be careful not to pull up the black hard drive plastic connector with the sticker. Also, removing this sticker will void your warranty.
    • Locate the HP product sticker, a black square sticker covered with product details, at the top of the computer.
    • Pull off the HP product sticker, starting at the top right corner and pulling diagonally down towards the bottom right.
    • Be careful not to pull up the black hard drive plastic connector with the sticker. Also, removing this sticker will void your warranty.
    • Remove the HP product sticker.
  6. Locate the hard drive, where the HP Product sticker used to be. Locate the hard drive cable, connected to the hard drive.
    • Locate the hard drive, where the HP Product sticker used to be.
    • Locate the hard drive cable, connected to the hard drive.
    • Disconnect the hard drive cable by gently pulling upward.
  7. Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 x 4.0 Philips screws holding the hard drive in place. Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 x 4.0 Philips screws holding the hard drive in place.
    • Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 x 4.0 Philips screws holding the hard drive in place.
  8. Use the Mylar Tab located on the right side of the hard drive to pry up the hard drive. Remove the hard drive.
    • Use the Mylar Tab located on the right side of the hard drive to pry up the hard drive.
    • Remove the hard drive.
  9. Lay the hard drive down with the underside facing up.
    • Lay the hard drive down with the underside facing up.
    • Pull and remove the hard drive pin connector from the hard drive.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Alek Linquist
120 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-23, Amido Fall 2012 Mitglied von Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 2,005
