Einleitung
If you are having problems with internet connection, you may want to replace your wireless network card on your HP Mini 311.
Ersatzteile
Kein Ersatzteil erforderlich.
Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
Kommentar hinzufügen
Slide the battery away from the device to remove.
  • Slide the battery away from the device to remove.
  • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
  • The screws will remain in the shied.
  • Lift the memory shield up and remove from the laptop.
  • Begin by removing the red and blue wires from the wireless card.
  • Gently remove to avoid damaging the ends of the wires.
  • Remove the two Phillips 00 3.8mm screws attached to the wireless card.
  • Lift up the unattached side of the wireless card and pull out to remove.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Christian Santoyo
Mitglied seit 31.01.2013
369 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 20-4, Maness Winter 2013 Mitglied von Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 971
