Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the screws highlighted to remove. We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery. We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery.
    • Locate the screws highlighted to remove.
    • We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery.
  2. Remove the middle back lid shown in the image. May require a bit of force. If it is not coming out try the other side.
    • Remove the middle back lid shown in the image.
    • May require a bit of force. If it is not coming out try the other side.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Go around the edges with a special tool to pop lid out of place.
    • Go around the edges with a special tool to pop lid out of place.
  5. Once all corners are popped out of place lift the cover up slowly.
    • Once all corners are popped out of place lift the cover up slowly.
    • Lifting the lid should not require much force.
Abschluss
Raul Rodriguez
289 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
Insgesamt: 97
