Was du brauchst
Locate the two slots on the bottom of the laptop to unlock the battery.
Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force.
Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
