Zum Hauptinhalt wechseln
Einleitung
This outline will teach you how to unlock the battery to easily slide out of place without damaging the laptop.
  1. Locate the two slots on the bottom of the laptop to unlock the battery.
    • Locate the two slots on the bottom of the laptop to unlock the battery.
  2. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  3. Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force. Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force.
    • Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force.
Abschluss
Raul Rodriguez
289 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
Insgesamt: 94
