Zum Hauptinhalt wechseln
HP Notebook 15-ay011nr Hard Drive Replacement
Was du brauchst
    • Before disassembling the computer, follow these steps:
    • Shut down the computer
    • If you are unsure whether the computer is in hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect all external devices connected to the computer
    • Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
  1. HP Notebook 15-ay011nr Hard Drive Replacement, Removing the battery: Schritt 2, Bild 1 von 1
    • To remove the battery:
    • Position the computer upside down on a flat surface
    • Slide the battery lock latch (1)
    • Slide the battery release latch (2)
    • Remove the battery (3) from the computer
  2. HP Notebook 15-ay011nr Hard Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 1
    • To remove the optical drive:
    • Remove the Philips PM2.5x6.0 screw (1)
    • Remove the optical drive (2) by sliding it out of the optical drive bay
  3. HP Notebook 15-ay011nr Hard Drive Replacement, Bottom Cover: Schritt 4, Bild 1 von 1
    • To remove the bottom cover:
    • Position the computer upside down the the front toward you
    • Remove the two rubber feet from the rear of the bottom of the computer (1)
    • Remove the 11 Philips PM2.5x6 screws (2) from the bottom of the computer
    • Remove the 2 Philips PM2x2 screws (3) from the optical drive bay
  4. HP Notebook 15-ay011nr Hard Drive Replacement, Solid-state drive: Schritt 5, Bild 1 von 1
    • Remove the solid-state drive
    • Remove the Philips PM2x2 screw (1) that secures the drive to the system board
    • Remove the drive (2) by pulling it away from the connector
Abschluss
Alec Ringberg
625 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 831
