Einleitung
This guide will give a step by step instruction on how to remove and replace a battery in an HP Notebook 15-ba018ds. Use this guide if you're having problems with a faulty battery.
Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
