Zum Hauptinhalt wechseln
HP OMEN 16 Series Hard Drive Replacement
Was du brauchst
  1. HP OMEN 16 Series Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 HP OMEN 16 Series Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 HP OMEN 16 Series Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Remove the four 8 mm screws from the back panel of the laptop using a Phillips #1 screwdriver.
    • Remove the four 5 mm screws from the back panel of the laptop using a Phillips #1 screwdriver.
    • Slide a small plastic card between the crevice of the back panel of the laptop and the laptop itself.
    • Turn the card clockwise until you have a wide gap between the back panel and the laptop. Repeat this step all around the laptop to remove the back panel.
    • DO NOT insert the card too deep into the laptop, or you may damage or break the components inside the computer. Like the picture, you only need to insert a small corner of the card into the laptop.
  2. HP OMEN 16 Series Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP OMEN 16 Series Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Locate the hard drive on the right.
    • Remove the screw fastening the hard drive in place with a Phillips #1 screwdriver.
  3. HP OMEN 16 Series Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP OMEN 16 Series Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP OMEN 16 Series Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • The SSD will pop up at a 25 or 35-degree angle.
    • Take the SSD out slowly at an angle. You may need to slightly wiggle the SSD out.
  4. HP OMEN 16 Series Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP OMEN 16 Series Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP OMEN 16 Series Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Insert the new SSD into the slot at an angle without applying much pressure.
    • Re-screw the new SSD in with the Phillips #1 screwdriver.
  5. HP OMEN 16 Series Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP OMEN 16 Series Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP OMEN 16 Series Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Locate the spare hard drive slot on the left side of the laptop.
    • Remove the screw from the spare hard drive slot, and set it carefully aside for later.
    • Obtain your new hard drive and insert the hard drive at around a 25 to 35-degree angle, as shown in the image.
    • Again, insert the hard drive carefully, and do not apply much pressure.
  6. HP OMEN 16 Series Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP OMEN 16 Series Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Screw the hard drive securely to the hard drive slot using the screw that was set aside in step 5.
  7. HP OMEN 16 Series Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP OMEN 16 Series Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Obtain the back panel and push the panel back onto the laptop.
    • Make sure that the panel is on the laptop completely; this means that you should push down firmly on multiple places so that the cover is securely on the laptop.
    • Re-screw in the four 8 mm screws with the Phillips #1 screwdriver.
    • Re-screw in the four 5 mm screws with the Phillips #1 screwdriver.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
James Heo
172 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 4-11, Kershman Fall 2023 Mitglied von CSU Los Angeles, Team 4-11, Kershman Fall 2023
CSULA-KERSHMAN-F23S4G11
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 59
Letzte 30 Tage: 241
Insgesamt: 936
