Einleitung
This guide will show you how to remove the LCD display.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. There is a hidden screw underneath the model sticker on the front panel. Peel the model sticker off the cover. This will expose the T10 screw securing the panel.
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. Remove the single 12mm-T10 screw securing the front panel to the printer body. Loosen the panel cover from the printer body. There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Gently remove the No-Fuss ribbon cable from the front panel. Gently remove the No-Fuss ribbon cable from the front panel. Gently remove the No-Fuss ribbon cable from the front panel.
    • Gently remove the No-Fuss ribbon cable from the front panel.
  5. Remove the seven 8mm screws using the Torx T6 screwdriver. Remove the motherboard from the front-panel housing. The LCD display is on the opposite side.
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Justin Engwall
137 Reputation
1 Anleitung geschrieben
Cal Poly, Team S18-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 272
