Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to replace the power supply in your HP Officejet 4630. The power supply is easy to replace and can be done with only a screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Lift the hood of the printer. Lift the hood of the printer. Lift the hood of the printer.
    • Lift the hood of the printer.
  2. Remove the two T10 11mm screws. Remove the two T10 11mm screws. Remove the two T10 11mm screws.
    • Remove the two T10 11mm screws.
  3. Remove the panels covering the power brick and cord. Remove the panels covering the power brick and cord. Remove the panels covering the power brick and cord.
    • Remove the panels covering the power brick and cord.
  4. Remove the cord from the power supply. Remove the cord from the power supply.
    • Remove the cord from the power supply.
  5. Slide the power supply out from the chassis. The power supply is still attached; don't pull too quickly. The power supply is still attached; don't pull too quickly.
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  6. Remove final cable from power supply.
    • Remove final cable from power supply.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Maya Willis
349 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S18-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Mitglieder
7 Anleitungen geschrieben
Would like to know a reliable source for the
A9T80-80006 power adapter that does not cost 1/3 rd the price of a new printer
Mark Stephen - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 4
Letzte 7 Tage: 37
Letzte 30 Tage: 196
Insgesamt: 2,420
